Saltar al contenido principal
MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement
Qué necesitas
  1. MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Power off the compressor: paso 1, imagen 1 de 2 MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Power off the compressor: paso 1, imagen 2 de 2
    • Before you begin, ensure the device is powered down and cool to the touch.
    • Ensure the compressor is unplugged.
    • Flip the pressure switch lever up to the off position.
  2. MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Drain the air from the compressor: paso 2, imagen 1 de 2 MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Drain the air from the compressor: paso 2, imagen 2 de 2
    • Pull the ring on the safety release valve away from the compressor tank to drain the air from the compressor.
    • Ensure all air is drained from the tank before beginning repairs.
  3. MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Remove the air hose quick-connect socket: paso 3, imagen 1 de 2 MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Remove the air hose quick-connect socket: paso 3, imagen 2 de 2
    • Use a 3/4 inch wrench to loosen and remove the air hose quick-connect socket.
  4. MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Remove the pressure gauge: paso 4, imagen 1 de 2 MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Remove the pressure gauge: paso 4, imagen 2 de 2
    • Use a 7/16 inch wrench to loosen and remove the pressure gauge.
  5. MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement, Remove the regulator: paso 5, imagen 1 de 1
    • Use a 5/8" wrench to loosen the air tank nipple from the air tank enough to be able to rotate it with the regulator.
  6. MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement: paso 6, imagen 1 de 3 MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement: paso 6, imagen 2 de 3 MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement: paso 6, imagen 3 de 3
    • Rotate the regulator 180°, so the bottom of the regulator faces away from the compressor motor.
  7. MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement: paso 7, imagen 1 de 3 MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement: paso 7, imagen 2 de 3 MiTM Air Compressors AM1HE0205HD 2014 Regulator Replacement: paso 7, imagen 3 de 3
    • With a 5/8 inch wrench bracing the air tank nipple, use a 3/4 inch wrench to loosen and remove the regulator.
    • Make sure the nipple stays connected to the air tank.
    • During reassembly, tighten the air tank nipple to the air tank, and then tighten the regulator to the nipple.
Conclusión
Adam O'Camb
Miembro Desde 04/11/15
199,443 Reputación
416 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 145
