Introducción
You may have broken the display to your Minimove boombox. This guide will direct you in removing the current display and re-installing a new one. The display is part of a daughterboard that must be replaced altogether if your display is not working. This guide will require extensive disassembly of the Minimove.
Qué necesitas
Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
Remove the bottom panel of the boombox by carefully pulling the panel straight backwards from the boombox until the boards are free.
Locate and unscrew the four 8mm screws (in red) along the edge with a Phillips #1 screwdriver.
Unscrew the two 12mm screws (in orange) on the inside of the daughterboard.
2 personas más completaron esta guía.
