Saltar al contenido principal
Memorex CD Alarm Clock Radio Antenna Replacement
Qué necesitas
  1. Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: paso 1, imagen 1 de 3 Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: paso 1, imagen 2 de 3 Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: paso 1, imagen 3 de 3
    • Turn the clock radio over so the bottom is facing up.
    • Pull the tab upward and remove the cover from the battery compartment.
    • Remove the batteries.
  2. Memorex CD Alarm Clock Radio Antenna Replacement: paso 2, imagen 1 de 3 Memorex CD Alarm Clock Radio Antenna Replacement: paso 2, imagen 2 de 3 Memorex CD Alarm Clock Radio Antenna Replacement: paso 2, imagen 3 de 3
    • Remove the five screws on the bottom of the device with a screwdriver.
    • Grasp the top and bottom and gently pull apart.
  3. Memorex CD Alarm Clock Radio Antenna Replacement, Antenna: paso 3, imagen 1 de 1
    • Locate the small silver transistor between the front left speaker and the tuning knob. The antenna should be attached directly below the transistor.
    • Deolder the antenna wire from the circuit board, and remove the wire.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 846
