Saltar al contenido principal
Maze Speed SSB-508 Battery Port Replacement
Qué necesitas
  1. Maze Speed SSB-508 Battery Port Replacement, Motherboard: paso 1, imagen 1 de 3 Maze Speed SSB-508 Battery Port Replacement, Motherboard: paso 1, imagen 2 de 3 Maze Speed SSB-508 Battery Port Replacement, Motherboard: paso 1, imagen 3 de 3
    • Remove the back cover by inserting the plastic opening tool at the bottom left corner of the device.
  2. Maze Speed SSB-508 Battery Port Replacement: paso 2, imagen 1 de 2 Maze Speed SSB-508 Battery Port Replacement: paso 2, imagen 2 de 2
    • Remove fifteen 2mm Phillips #00 screws.
  3. Maze Speed SSB-508 Battery Port Replacement: paso 3, imagen 1 de 3 Maze Speed SSB-508 Battery Port Replacement: paso 3, imagen 2 de 3 Maze Speed SSB-508 Battery Port Replacement: paso 3, imagen 3 de 3
    • Lift the plastic opening tool up at the bottom left corner to create the gap.
    • Repeat this through all corners to remove the internal casing.
  4. Maze Speed SSB-508 Battery Port Replacement: paso 4, imagen 1 de 3 Maze Speed SSB-508 Battery Port Replacement: paso 4, imagen 2 de 3 Maze Speed SSB-508 Battery Port Replacement: paso 4, imagen 3 de 3
    • Unscrew the 2mm screw at the bottom right of the motherboard.
    • Remove the internal antenna casing from the motherboard.
  5. Maze Speed SSB-508 Battery Port Replacement: paso 5, imagen 1 de 2 Maze Speed SSB-508 Battery Port Replacement: paso 5, imagen 2 de 2
    • Unplug the speaker at the top of the motherboard.
  6. Maze Speed SSB-508 Battery Port Replacement: paso 6, imagen 1 de 2 Maze Speed SSB-508 Battery Port Replacement: paso 6, imagen 2 de 2
    • Desolder the gold ribbon that is connected to the motherboard at the bottom left corner.
  7. Maze Speed SSB-508 Battery Port Replacement: paso 7, imagen 1 de 3 Maze Speed SSB-508 Battery Port Replacement: paso 7, imagen 2 de 3 Maze Speed SSB-508 Battery Port Replacement: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to remove cable from the ZIF connectors located at the bottom left of the motherboard.
    • Use the tweezers to remove the second cable from ZIF connector located to the right of the speaker that you unplugged in step five.
    • ZIF connector stands for Zero Insertion Force. Flip the small locking tap before removing the cable.
  8. Maze Speed SSB-508 Battery Port Replacement: paso 8, imagen 1 de 2 Maze Speed SSB-508 Battery Port Replacement: paso 8, imagen 2 de 2
    • At this point, the motherboard should be able to be lifted up from the bottom.
    • Use the tweezers to dislodge the speaker.
    • After the speaker is dislodged, flip the motherboard up so that you can see the cable.
    • Using a soldering tool, desolder the cable from the back of the motherboard.
  9. Maze Speed SSB-508 Battery Port Replacement: paso 9, imagen 1 de 1
    • Remove the motherboard from the back.
  10. Maze Speed SSB-508 Battery Port Replacement, Battery Port: paso 10, imagen 1 de 3 Maze Speed SSB-508 Battery Port Replacement, Battery Port: paso 10, imagen 2 de 3 Maze Speed SSB-508 Battery Port Replacement, Battery Port: paso 10, imagen 3 de 3
    • Flip the motherboard upside down and you will see the battery port connected to the motherboard with 5 different soldered places.
    • Use the pliers to hold the motherboard and desolder the 5 places which are connected to the motherboard.
  11. Maze Speed SSB-508 Battery Port Replacement: paso 11, imagen 1 de 1
    Comprar
    • Use the tweezers to pull out the battery port.
    • Then, replace it with the new battery port.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 33
Todo El Tiempo: 1,234
