Saltar al contenido principal
Maquet Servo-U O2 Supply Replacement
  1. Maquet Servo-U O2 Supply Replacement, O2 Supply: paso 1, imagen 1 de 1
    • Turn the inspiratory channel lock one quarter of a turn to release.
    • Lift off the inspiratory channel cover.
    • WARNING! The inspiratory channel cover shall be kept in place once maintenance has been performed. Otherwise the gas modules can be affected and deliver the wrong flow.
  2. Maquet Servo-U O2 Supply Replacement: paso 2, imagen 1 de 1
    • Lower the locking catch.
  3. Maquet Servo-U O2 Supply Replacement: paso 3, imagen 1 de 2 Maquet Servo-U O2 Supply Replacement: paso 3, imagen 2 de 2
    • Disconnect the O2 cell connector.
    • Lift and discard the O2 cell with the rubber seal to special waste and/or remove and discard the bacterial filter to hazardous waste.
  4. Maquet Servo-U O2 Supply Replacement: paso 4, imagen 1 de 1
    • Ensure that the new rubber seal is intact, then firmly put in a new bacterial filter.
  5. Maquet Servo-U O2 Supply Replacement: paso 5, imagen 1 de 1
    • Connect the O2 cell connector.
    • Put the O2 cell in position.
    • Close the locking catch.
  6. Maquet Servo-U O2 Supply Replacement: paso 6, imagen 1 de 1
    • Put the inspiratory channel cover in position.
    • Tighten the inspiratory channel lock.
    • Perform a pre-use check stated in Troubleshooting Page.
Linea de Meta
Equipo
Cal Poly, Team S7-G2, Paton Spring 2020 Miembro de Cal Poly, Team S7-G2, Paton Spring 2020
CPSU-PATON-S20S7G2
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 11
Ultimos 30 días: 42
Todo El Tiempo: 2,089
