Introducción
Use this guide to replace the power cord in a Makita Jack Hammer HM1203C 2010.
Qué necesitas
Use a Phillips #2 screwdriver to remove two screws securing the handle cover.
Use a Phillips #2 screwdriver to remove the screw securing the power cord bracket.
Herramienta utilizada en este paso:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use a 2.5 mm flathead screwdriver to loosen the two set screws holding in the power cord wires.
Use 10 gauge wire strippers to strip about 1/8 inch of insulation off of each wire of the new power cord.
2 personas más completaron esta guía.
