Introducción
Follow this guide to remove and replace the chain brake band for a Makita chainsaw.
Optional tools:
- Chainsaw scrench
Qué necesitas
Use a 13 mm socket to remove the two nuts securing the sprocket guard plate.
If the chainsaw has a chain and guide bar installed, follow the manufacturer's instructions and remove them before proceeding.
Pull the hand guard towards the tubular handle until you hear a click to release the chain brake.
Remove the four 12 mm long T27 screws securing the chain brake cover.
Use a small pry bar to pry the brake band out of its groove.
Swing the brake band out and carefully unhook it from the right linkage.
4 comentarios
Any way to reset the brake if it is accidentally engaged?
Yes! You can use the handle to dis-engage the brake again.
If the stiff tension spring pops off how do you put it back on?
Hi Kelly!
You can try to slide the spring into place using a screwdriver.
Set the chain brake in brake mode. Hook the straight end of the tension spring in its groove. Place the flat end of a large flathead screwdriver against the round peg where the curled end of the spring should hook on. Tilt the screwdriver until you can hook the spring onto the screwdriver shank. Carefully straighten the screwdriver to tension the spring, and push the spring off onto the peg.
