Saltar al contenido principal
Making a low cost photography light stand
Qué necesitas
  1. Making a low cost photography light stand, Unplug the lamp: paso 1, imagen 1 de 1
    • Before disassembling on the lamp, it MUST be unplugged!
  2. Making a low cost photography light stand, Remove the lightbulb: paso 2, imagen 1 de 3 Making a low cost photography light stand, Remove the lightbulb: paso 2, imagen 2 de 3 Making a low cost photography light stand, Remove the lightbulb: paso 2, imagen 3 de 3
    • If the bulb is worth keeping, this can be reused.
    • If the lamp has a lightbulb installed, remove it from the lamp.
  3. Making a low cost photography light stand, Remove the socket cover: paso 3, imagen 1 de 3 Making a low cost photography light stand, Remove the socket cover: paso 3, imagen 2 de 3 Making a low cost photography light stand, Remove the socket cover: paso 3, imagen 3 de 3
    • MOST LAMPS WILL BE SIMILAR, but designs can vary.
    • Remove the switch handle. Note: While this can be optional, it was required on this lamp. If it looks tied into something, it probably has to be removed.
    • Remove the socket cover. Once removed, remove the bulb socket.
  4. Making a low cost photography light stand, Remove the bulb socket: paso 4, imagen 1 de 2 Making a low cost photography light stand, Remove the bulb socket: paso 4, imagen 2 de 2
    • Sockets that hold the cord in with a press-fit design are hard to reuse by design. Unless you can depress the cord, cut the cord at the socket and discard the bulb socket.
    • After removing the plastic cover and switch, remove the bulb socket with a Phillips #2 screwdriver. If your socket is press fit, these are generally not reusable. Cut the cord unless you can pull the cord and not compromise the socket.
    • Discard any broken or unwanted components.
  5. Making a low cost photography light stand, Remove the cord: paso 5, imagen 1 de 3 Making a low cost photography light stand, Remove the cord: paso 5, imagen 2 de 3 Making a low cost photography light stand, Remove the cord: paso 5, imagen 3 de 3
    • Keep the cord if it is in good shape. These are excellent to keep around to repair other lamps (or anything in need of a similar cord).
    • After removing the bulb socket, remove the power cord.
  6. Making a low cost photography light stand, Test the lamp and find a good clamp point: paso 6, imagen 1 de 1
    • After gutting the lamp, find a good spot to clamp a workshop light on like the one shown. Additional changes like height reduction can also be done at this stage.
Linea de Meta
Nick
Miembro Desde 11/10/09
88,899 Reputación
49 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,539 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 12
Todo El Tiempo: 455
