Saltar al contenido principal
Magic Bullet NutriBullet Activator Replacement
Qué necesitas
  1. Magic Bullet NutriBullet Activator Replacement, Curve Base: paso 1, imagen 1 de 1
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Magic Bullet NutriBullet Activator Replacement: paso 2, imagen 1 de 2 Magic Bullet NutriBullet Activator Replacement: paso 2, imagen 2 de 2
    • Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
  3. Magic Bullet NutriBullet Activator Replacement: paso 3, imagen 1 de 1
    • Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
    • Once the plastic base is removed, there is a fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
  4. Magic Bullet NutriBullet Activator Replacement: paso 4, imagen 1 de 1
    • Lift the power cord to remove it from the side slot on the curved base.
  5. Magic Bullet NutriBullet Activator Replacement: paso 5, imagen 1 de 2 Magic Bullet NutriBullet Activator Replacement: paso 5, imagen 2 de 2
    • Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
    • The white safety bracket holds the cord down. After removing it, the cord will be loosened.
  6. Magic Bullet NutriBullet Activator Replacement: paso 6, imagen 1 de 1
    • Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
  7. Magic Bullet NutriBullet Activator Replacement: paso 7, imagen 1 de 1
    • Use slight tension to remove the curved base by lifting it upward off of the outside casing.
  8. Magic Bullet NutriBullet Activator Replacement, Outside Casing: paso 8, imagen 1 de 1
    • Wiggle the outside casing upward until it separates from the powerbase.
    • Hold the ring at the bottom of the powerbase to receive a better grip.
  9. Magic Bullet NutriBullet Activator Replacement, Rubber Covers: paso 9, imagen 1 de 1
    • Place the NutriBullet powerbase on the table so that the white activators are visible. Remove the three rubber protectors from the activators using either tweezers or your fingers.
  10. Magic Bullet NutriBullet Activator Replacement, Top Screws: paso 10, imagen 1 de 1
    • Remove the three 15mm screws with the Philips Head 2 Screwdriver.
  11. Magic Bullet NutriBullet Activator Replacement: paso 11, imagen 1 de 1
    • Turn the NutriBullet powerbase upside down and remove the plastic casing by lifting it up.
  12. Magic Bullet NutriBullet Activator Replacement: paso 12, imagen 1 de 1
    • Determine which activator(s) fail to work by applying pressure to them. Then, remove the two 15mm screws that hold the activators in place by using the Philips Head 2 screwdriver.
    • Only two of the three activator tabs have green micro switches that actually turn on the motor. Use a circuit tester on the power chord and press the two micro switches simultaneously to see if they complete the circuit. If not, one or both need to be replaced.
  13. Magic Bullet NutriBullet Activator Replacement: paso 13, imagen 1 de 3 Magic Bullet NutriBullet Activator Replacement: paso 13, imagen 2 de 3 Magic Bullet NutriBullet Activator Replacement: paso 13, imagen 3 de 3
    • Using slight tension, pull the loose activator from the slot.
    • The white plastic activator should fall out and they can now be replaced.
  14. Magic Bullet NutriBullet Activator Replacement, Repairing switch internally: paso 14, imagen 1 de 1
    • Open up the green switch. The metal tab and black button will fall out. Fiddle around with the metal switch on the inside to snap it back into place and then reassemble carefully. It should make a clicking noise.
Conclusión
55 personas más completaron esta guía.
Angela Wong
Miembro Desde 01/22/15
1,081 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 19-8, Maness Winter 2015 Miembro de Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Miembros
7 Guías creadas
43 comentarios
Seems to be almost complete info, however, where and how do I get the replacement parts?
Thank you!
Love&Peace!
Glow
Glow Wo - Contestar
Could you please let me know where I might be able to obtain replacement activators? Mind broke when cleaning the machine.
Ron - Contestar
Thank you. I would have went nuts looking for the screw under the rubber pieces. Would have probably destroyed the whole machine.
Joe Bailey - Contestar
Thanks for the demonstration!
D S Jones - Contestar
Perfect! Nice little machine that can still be serviced, unlike most of what is made today.
cward6681 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 19
Ultimos 7 días: 132
Ultimos 30 días: 563
Todo El Tiempo: 77,356
