Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Faulty Wi-Fi or Bluetooth connection? Replace the AirPort/Bluetooth cable.
  1. Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly. Slightly lift the lower case near the vent opening. Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
  3. For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    • It may be easier to use your fingernails to lift up on both sides of the connector.
  4. Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board. Carefully peel the AirPort/Bluetooth ribbon cable from its channel within the rear speaker assembly.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
    • Carefully peel the AirPort/Bluetooth ribbon cable from its channel within the rear speaker assembly.
  5. Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the right speaker.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the right speaker.
Conclusión
10 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 23
Todo El Tiempo: 13,786
