Saltar al contenido principal
MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement
Qué necesitas
  1. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, Lower Case: paso 1, imagen 1 de 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: paso 2, imagen 1 de 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: paso 2, imagen 2 de 2
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: paso 3, imagen 1 de 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: paso 3, imagen 2 de 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: paso 3, imagen 3 de 3
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
  4. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, Battery Connector: paso 4, imagen 1 de 1
    • Peel back the sticker covering the battery connector.
  5. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: paso 5, imagen 1 de 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: paso 5, imagen 2 de 3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: paso 5, imagen 3 de 3
    • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
    • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  6. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, I/O Board Cable (Top): paso 6, imagen 1 de 1
    • Remove the four 2.2 mm T5 Torx screws securing the I/O board cable connector covers.
  7. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: paso 7, imagen 1 de 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: paso 7, imagen 2 de 2
    • Remove the left connector cover.
    • Use the flat end of a spudger to pry the left end of the I/O board cable up from its socket on the logic board.
  8. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: paso 8, imagen 1 de 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: paso 8, imagen 2 de 2
    • Remove the right connector cover.
    • Use the flat end of a spudger to pry the right end of the I/O board cable up from its socket on the logic board.
  9. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: paso 9, imagen 1 de 1
    • Peel the I/O board cable up from the adhesive securing it to the fan.
    • Remove the cable.
Conclusión
3 personas más completaron esta guía.
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,817 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 20
Ultimos 30 días: 102
Todo El Tiempo: 8,956
