Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement
Qué necesitas
  1. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement, Battery: paso 1, imagen 1 de 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
    Pregunta a FixBot
    Agregar Comentario
  2. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement, RAM Shield: paso 2, imagen 1 de 1
    • Remove the three identical Phillips screws from the memory door.
    Pregunta a FixBot
    Agregar Comentario
  3. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 3, imagen 1 de 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
    Pregunta a FixBot
    Agregar Comentario
  4. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement, Upper Case: paso 4, imagen 1 de 1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
    Pregunta a FixBot
    Agregar Comentario
  5. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 5, imagen 1 de 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
    Pregunta a FixBot
    Agregar Comentario
  6. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 6, imagen 1 de 1
    • Remove the four 3.2 mm Phillips screws on the port side of the computer.
    Pregunta a FixBot
    Agregar Comentario
  7. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 7, imagen 1 de 1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
    Pregunta a FixBot
    Agregar Comentario
  8. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 8, imagen 1 de 1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
    Pregunta a FixBot
    Agregar Comentario
  9. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 9, imagen 1 de 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
    Pregunta a FixBot
    Agregar Comentario
  10. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 10, imagen 1 de 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
    Pregunta a FixBot
    Agregar Comentario
  11. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement, Upper Case: paso 11, imagen 1 de 1
    • Use a spudger to pry up the translucent plastic sheath covering the keyboard connector.
    Pregunta a FixBot
    Agregar Comentario
  12. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 12, imagen 1 de 1
    • Use the tip of a spudger to flip up the black plastic flaps locking down the keyboard and keyboard backlight ribbon cables.
    Pregunta a FixBot
    Agregar Comentario
  13. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 13, imagen 1 de 1
    • Slide the orange keyboard backlight ribbon out of its connector.
    Pregunta a FixBot
    Agregar Comentario
  14. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 14, imagen 1 de 1
    • Peel up the orange tape covering the keyboard backlight connector.
    Pregunta a FixBot
    Agregar Comentario
  15. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 15, imagen 1 de 1
    • Use the tip of a spudger to flip up the brown plastic flap locking down the keyboard backlight ribbon cable.
    Pregunta a FixBot
    Agregar Comentario
  16. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 16, imagen 1 de 1
    • Use a spudger or your finger to slide the keyboard backlight ribbon out of its connector.
    Pregunta a FixBot
    Agregar Comentario
  17. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 17, imagen 1 de 1
    • Carefully peel up the orange ribbon cable which carries the power and sleep signals, removing tape as necessary.
    Pregunta a FixBot
    Agregar Comentario
  18. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 18, imagen 1 de 1
    • Peel back the black protective sheath on the right side of the upper case. It is not necessary to fully remove this shield. Simply peel it back enough to access the screws beneath.
    Pregunta a FixBot
    Agregar Comentario
  19. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 19, imagen 1 de 1
    • Peel back the black protective sheath on the left side of the upper case. It is not necessary to fully remove this shield. Simply peel it back enough to access the screws beneath.
    Pregunta a FixBot
    Agregar Comentario
  20. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 20, imagen 1 de 1
    • Remove the ten identical Phillips screws attaching the keyboard to the casing.
    Pregunta a FixBot
    Agregar Comentario
  21. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 21, imagen 1 de 1
    • There are four locking tabs along the back edge of the keyboard holding it in place. These tabs must be straightened before you can remove the keyboard.
    Pregunta a FixBot
    Agregar Comentario
  22. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 22, imagen 1 de 1
    • The first frame shows a tab in the "locked" position and the second frame shows the same tab in the "unlocked" position.
    • Use needlenose pliers or a spudger to bend each of the four tabs so that they are all in the "unlocked" position.
    Pregunta a FixBot
    Agregar Comentario
  23. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 23, imagen 1 de 1
    • Slide the keyboard ribbon out of its connector.
    • If the keyboard ribbon won't slide out, make sure that the black plastic flap holding the ribbon in place is vertical.
    Pregunta a FixBot
    Agregar Comentario
  24. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 24, imagen 1 de 1
    • Place the upper casing on its edge and use a spudger to push the keyboard away from the casing, poking the spudger through the central keyboard screw hole. Grasp the keyboard as it separates from the casing.
    Pregunta a FixBot
    Agregar Comentario
  25. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 25, imagen 1 de 1
    • Maintaining your hold on the keyboard, lay the casing flat and gently bow the keyboard until the two tabs on either side of the keyboard come free.
    • Slide the keyboard away from the trackpad and out of the upper case.
    Pregunta a FixBot
    Agregar Comentario
  26. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 26, imagen 1 de 1
    • Remove the two Phillips screws securing the black antenna holder to the upper case.
    • Lift the black Bluetooth antenna holder off of the upper case.
    Pregunta a FixBot
    Agregar Comentario
  27. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 27, imagen 1 de 1
    • Disconnect the Bluetooth antenna cable from the Bluetooth board.
    Pregunta a FixBot
    Agregar Comentario
  28. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 28, imagen 1 de 1
    • Lift the Bluetooth antenna out of its housing in the upper case. The Bluetooth antenna is secured to the upper case with an adhesive, so rocking the antenna board from side to side may help it come free easier.
    Pregunta a FixBot
    Agregar Comentario
  29. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 29, imagen 1 de 1
    • Remove the single Phillips screw securing the Bluetooth board to the lower case.
    Pregunta a FixBot
    Agregar Comentario
  30. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 30, imagen 1 de 1
    • Peel up the Bluetooth data cable from the adhesive on the upper case.
    Pregunta a FixBot
    Agregar Comentario
  31. MacBook Pro 15" Core 2 Duo Model A1211 Upper Case Replacement: paso 31, imagen 1 de 1
    • Disconnect the Bluetooth data cable from the upper case.
    • Lift the Bluetooth board and attached cable off the upper case.
    • Upper case remains.
    • To install your replacement upper case, install your current Bluetooth board, antenna, and keyboard into the replacement case and reassemble your computer.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
7 personas más completaron esta guía.
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 15
Ultimos 30 días: 57
Todo El Tiempo: 24,763
