Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement
Qué necesitas
  1. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
    Pregunta a FixBot
    Agregar Comentario
  2. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement, RAM Shield: paso 2, imagen 1 de 1
    • Remove the three identical Phillips screws from the memory door.
    Pregunta a FixBot
    Agregar Comentario
  3. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement: paso 3, imagen 1 de 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
    Pregunta a FixBot
    Agregar Comentario
  4. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement, Upper Case: paso 4, imagen 1 de 1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
    Pregunta a FixBot
    Agregar Comentario
  5. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement: paso 5, imagen 1 de 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
    Pregunta a FixBot
    Agregar Comentario
  6. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement: paso 6, imagen 1 de 1
    • Remove the four 3.2 mm Phillips screws on the port side of the computer.
    Pregunta a FixBot
    Agregar Comentario
  7. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement: paso 7, imagen 1 de 1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
    Pregunta a FixBot
    Agregar Comentario
  8. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement: paso 8, imagen 1 de 1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
    Pregunta a FixBot
    Agregar Comentario
  9. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement: paso 9, imagen 1 de 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
    Pregunta a FixBot
    Agregar Comentario
  10. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement: paso 10, imagen 1 de 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
    Pregunta a FixBot
    Agregar Comentario
  11. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement, Optical Drive: paso 11, imagen 1 de 1
    • Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
    Pregunta a FixBot
    Agregar Comentario
  12. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement: paso 12, imagen 1 de 1
    • Remove the following 4 screws:
    • Two 3.3 mm silver Phillips screws on either side of the SuperDrive.
    • One 4.7 mm silver T6 Torx screw from the top left corner of the drive
    • One 6.2 mm black Phillips screw at the top right corner of the drive.
    Pregunta a FixBot
    Agregar Comentario
  13. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement: paso 13, imagen 1 de 1
    • Lift the optical drive up and out of the computer.
    Pregunta a FixBot
    Agregar Comentario
  14. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement, Optical Drive: paso 14, imagen 1 de 1
    • If your new optical drive already has brackets on it, you'll only need to transfer the data cable to your new drive.
    • Remove the two silver Phillips screws securing the mounting bracket to the left side of the optical drive.
    Pregunta a FixBot
    Agregar Comentario
  15. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement: paso 15, imagen 1 de 1
    • Rotate the drive and disconnect the orange ribbon cable from the optical drive.
    Pregunta a FixBot
    Agregar Comentario
  16. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement: paso 16, imagen 1 de 1
    • Remove the two Phillips screws securing the mounting bracket to the rear of the optical drive.
    Pregunta a FixBot
    Agregar Comentario
  17. MacBook Pro 15" Core 2 Duo Model A1211 Optical Drive Replacement: paso 17, imagen 1 de 1
    • Rotate the drive and remove the single Phillips screw securing the mounting bracket to the right side of the optical drive.
    • If you purchased an optical drive without mounting brackets, simply transfer the three silver metal brackets and orange ribbon cable to your new optical drive.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
81 personas más completaron esta guía.
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 19
Ultimos 30 días: 81
Todo El Tiempo: 123,986
