Introducción
Use this guide to replace a noisy or burned-out fan.
Partes
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
127 personas más completaron esta guía.
3 comentarios
Repair done as presented. The fan connection was a little tricky to get out but apart from that non eventful. New fan working nicely.
