Introducción
Use this guide to replace the LCD cable connected inside the hinge of your MacBook Pro Retina Display Assembly.
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Grasp the Interposer with tweezers.
Lift the Interposer off the logic board and remove it.
Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
The three cables are coded with black sleeves of different lengths. During reassembly:
Connect the long-sleeved cable to the socket closest to the ports.
The short-sleeved cable connects next to the screw.
The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
Grab the black pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Pull the display data cable straight out of its socket on the logic board.
With the display facing towards you and the plastic clutch cover down, grab the clutch cover and slide it all the way to the right, towards the hinge.
Lift the plastic cover from the bottom and remove it from the display.
11 personas más completaron esta guía.
3 comentarios
Hi,
Can anyone help me ? It might be possible that my MacBook Pro 13” early 2015 restarts by it self once in a few minutes because this cable is slightly damaged? It had before LCD problems and has been serviced. As I have noticed, when I touch the cable and move it a little bit, computer restarts immediately, so I thought this might be the restarting problem.
(I have to say that I have already tried other options : I have fresh reinstalled the operating system, so theres no software issue, I have repasted the processor, I have checked the cables connections). The only strange thing is that it doesn’t turn on with the battery disconnected…
Does anyone have any suggestion?
Thanks a lot!!
Are there instructions using the MacBook Pro (Retina, 15-inch, Early 2013)? The inside is completely different. Alas.
I'm getting this because the hing broke. The real problem is both hinges have broken. Seems like the other hinge is not possible to replace. Is that right? Will just this one side be enough to open with light use? My Mac is a early 2013 15inch pro. Model A1398
