Introducción
Restore balanced sound to your laptop by replacing the right speaker.
Herramientas
Partes
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Remove the following 3 screws:
One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
Lift the side of the optical drive closest to you, then slide the drive up and out of the computer.
First, slide its side nearest the rear of the Macbook under the edge of the rear frame to the left of the hinge, then lower the drive partially into the lower housing.
Before dropping the drive fully in place, use a spudger to push forward (towards the front of the drive) on the screw hole in the drive's mounting tab, to push forward the slider, which runs along the far side of the drive, to insert the end of this slider into a channel in the lower case's frame, which helps hold the drive in place.
Remove the following 4 Phillips screws:
Three 3 mm Phillips securing the subwoofer and right speaker to the lower case.
One 7.5 mm Phillips securing the loop in the display data cable to the lower case.
9 personas más completaron esta guía.
