Introducción
Replacing your lower case is easy! It only takes 10 screws.
  1. Unplug your MacBook Air and power it off before you proceed.
    • Unplug your MacBook Air and power it off before you proceed.
    • Remove ten Phillips screws securing the lower case to the MacBook Air:
      • Six 2.8 mm screws
      • Two 3.8 mm screws
      • Two 5.4 mm screws
  2. Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
    • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
Conclusión
13 personas más completaron esta guía.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 12
Últimos 30 Días: 31
Todo El Tiempo: 22,853
