Saltar al contenido principal
MacBook Air 15" 2024 Lower Case Replacement
Qué necesitas
  1. MacBook Air 15" 2024 Lower Case Replacement, Unfasten the lower case: paso 1, imagen 1 de 2 MacBook Air 15" 2024 Lower Case Replacement, Unfasten the lower case: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    FixMat
    $36.95
    • Use a P5 pentalobe screwdriver to remove the four 6.4 mm‑long screws securing the lower case.
  2. MacBook Air 15" 2024 Lower Case Replacement, Insert an opening pick: paso 2, imagen 1 de 3 MacBook Air 15" 2024 Lower Case Replacement, Insert an opening pick: paso 2, imagen 2 de 3 MacBook Air 15" 2024 Lower Case Replacement, Insert an opening pick: paso 2, imagen 3 de 3
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle to create a gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  3. MacBook Air 15" 2024 Lower Case Replacement, Release the snapping clips: paso 3, imagen 1 de 3 MacBook Air 15" 2024 Lower Case Replacement, Release the snapping clips: paso 3, imagen 2 de 3 MacBook Air 15" 2024 Lower Case Replacement, Release the snapping clips: paso 3, imagen 3 de 3
    • During the next two steps you'll feel and hear six snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next two clips.
  4. MacBook Air 15" 2024 Lower Case Replacement: paso 4, imagen 1 de 3 MacBook Air 15" 2024 Lower Case Replacement: paso 4, imagen 2 de 3 MacBook Air 15" 2024 Lower Case Replacement: paso 4, imagen 3 de 3
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the three remaining snapping clips.
  5. MacBook Air 15" 2024 Lower Case Replacement, Release the sliding tabs: paso 5, imagen 1 de 3 MacBook Air 15" 2024 Lower Case Replacement, Release the sliding tabs: paso 5, imagen 2 de 3 MacBook Air 15" 2024 Lower Case Replacement, Release the sliding tabs: paso 5, imagen 3 de 3
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat to the frame and firmly slide it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
  6. MacBook Air 15" 2024 Lower Case Replacement, Remove the lower case: paso 6, imagen 1 de 3 MacBook Air 15" 2024 Lower Case Replacement, Remove the lower case: paso 6, imagen 2 de 3 MacBook Air 15" 2024 Lower Case Replacement, Remove the lower case: paso 6, imagen 3 de 3
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the six snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
Conclusión
Una persona más ha completado esta guía.
Spencer Day
Miembro Desde 09/14/22
140,545 Reputación
951 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 122
23,272 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 20
Ultimos 30 días: 100
Todo El Tiempo: 1,380
