Saltar al contenido principal
MacBook Air 13" Early 2014 Right Speaker Replacement
Qué necesitas
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  1. MacBook Air 13" Early 2014 Right Speaker Replacement: paso 2, imagen 1 de 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. MacBook Air 13" Early 2014 Right Speaker Replacement, Battery: paso 3, imagen 1 de 1
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
  3. MacBook Air 13" Early 2014 Right Speaker Replacement: paso 4, imagen 1 de 1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
  4. MacBook Air 13" Early 2014 Right Speaker Replacement: paso 5, imagen 1 de 1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  5. MacBook Air 13" Early 2014 Right Speaker Replacement, Right Speaker: paso 6, imagen 1 de 1
    • Use the flat end of a spudger to pry the right speaker connector up and out of its socket on the logic board.
    • Pry up from beneath the wires.
  6. MacBook Air 13" Early 2014 Right Speaker Replacement: paso 7, imagen 1 de 3 MacBook Air 13" Early 2014 Right Speaker Replacement: paso 7, imagen 2 de 3 MacBook Air 13" Early 2014 Right Speaker Replacement: paso 7, imagen 3 de 3
    • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
    • Remove the right speaker from the upper case.
Conclusión
9 personas más completaron esta guía.
Jeff Suovanen
Miembro Desde 08/06/13
406,006 Reputación
258 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
137 Miembros
17,047 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 40
Todo El Tiempo: 4,285
