Introducción
Use this guide to replace a damaged I/O board ribbon cable.
Herramientas
Partes
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
The following connector has an especially deep socket. Use care when disconnecting it.
While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
Remove the I/O board cable.
3 personas más completaron esta guía.
