Introducción
Learn how to upgrade or replace the memory in your 2018 Mac mini with this RAM replacement guide. The mini can support up to 64 GB of RAM, using any combination of 8 GB, 16 GB, or 32 GB DDR4-2666 SODIMM RAM modules.
Qué necesitas
Resumen del Video
Herramienta utilizada en este paso:Magnetic Project Mat$19.95
Remove six TR6 Torx security screws securing the antenna plate, of the following lengths:
Three 4.1 mm shoulder screws
Three 1.8 mm screws
Use a T6 Torx driver to remove the four 7.2 mm screws securing the fan:
Two screws securing the fan to the logic board
Two screws with rubber shoulders securing the fan to the exhaust vent
Grasp the power supply cable and lift to disconnect it from the logic board, wiggling as needed to loosen it up.
396 personas más completaron esta guía.
152Guía Comentarios
Thank you so much! I’m curious about CPU. Is it possible to replace it?
No, the CPU is soldered to the logic board.
https://www.youtube.com/watch?v=2UrSLnnM... complete RAM upgrade video
Looks like the SSD is replaceable as well. Any idea on what kind of standard it follows?
looks like soldered to me. either way, with that T2 chip on board one shall not pass through…
