Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Mac mini (PowerPC) Bluetooth Antenna Replacement
Qué necesitas
  1. Mac mini (PowerPC) Bluetooth Antenna Replacement, Top Housing: paso 1, imagen 1 de 2 Mac mini (PowerPC) Bluetooth Antenna Replacement, Top Housing: paso 1, imagen 2 de 2
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
    Pregunta a FixBot
    Agregar Comentario
  2. Mac mini (PowerPC) Bluetooth Antenna Replacement: paso 2, imagen 1 de 3 Mac mini (PowerPC) Bluetooth Antenna Replacement: paso 2, imagen 2 de 3 Mac mini (PowerPC) Bluetooth Antenna Replacement: paso 2, imagen 3 de 3
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
    Pregunta a FixBot
    Agregar Comentario
  3. Mac mini (PowerPC) Bluetooth Antenna Replacement: paso 3, imagen 1 de 2 Mac mini (PowerPC) Bluetooth Antenna Replacement: paso 3, imagen 2 de 2
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
    Pregunta a FixBot
    Agregar Comentario
  4. Mac mini (PowerPC) Bluetooth Antenna Replacement: paso 4, imagen 1 de 2 Mac mini (PowerPC) Bluetooth Antenna Replacement: paso 4, imagen 2 de 2
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
    Pregunta a FixBot
    Agregar Comentario
  5. Mac mini (PowerPC) Bluetooth Antenna Replacement: paso 5, imagen 1 de 2 Mac mini (PowerPC) Bluetooth Antenna Replacement: paso 5, imagen 2 de 2
    • Keep working around the perimeter, freeing the clips along the final edge.
    Pregunta a FixBot
    Agregar Comentario
  6. Mac mini (PowerPC) Bluetooth Antenna Replacement: paso 6, imagen 1 de 2 Mac mini (PowerPC) Bluetooth Antenna Replacement: paso 6, imagen 2 de 2
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
    Pregunta a FixBot
    Agregar Comentario
  7. Mac mini (PowerPC) Bluetooth Antenna Replacement, Mass Storage Unit: paso 7, imagen 1 de 1
    • If your mini does not have Airport installed, then skip this step.
    • Grasp the Airport antenna board and lift it off of the two plastic posts holding it in place. You may need to push back the black plastic tab jutting through the lower left corner of the board.
    Pregunta a FixBot
    Agregar Comentario
  8. Mac mini (PowerPC) Bluetooth Antenna Replacement: paso 8, imagen 1 de 1
    • Remove the yellow tape securing the power button cable to the black plastic framework.
    Pregunta a FixBot
    Agregar Comentario
  9. Mac mini (PowerPC) Bluetooth Antenna Replacement: paso 9, imagen 1 de 1
    • Remove the three black Phillips screws securing the plastic framework to the logic board and lower case.
    Pregunta a FixBot
    Agregar Comentario
  10. Mac mini (PowerPC) Bluetooth Antenna Replacement: paso 10, imagen 1 de 1
    • Grasp the optical drive and mass storage unit in one hand and lift up enough so that you can see beneath it.
    Pregunta a FixBot
    Agregar Comentario
  11. Mac mini (PowerPC) Bluetooth Antenna Replacement: paso 11, imagen 1 de 1
    • If your mini has neither an Airport card nor a Bluetooth board, you can simply lift the optical drive up and away. Otherwise, you need to disconnect the Airport and/or Bluetooth antenna cables first.
    • With your free hand, pull the Bluetooth cable up from Bluetooth board and unplug the Airport antenna cable from the right of the Airport card. Caution: both of these connections are very small. When re-assembling unit after repair, you may want to remove the two screws holding the airport card to the assembly and lift the card up and out to re-attach the cables.
    Pregunta a FixBot
    Agregar Comentario
  12. Mac mini (PowerPC) Bluetooth Antenna Replacement, Bluetooth Antenna: paso 12, imagen 1 de 1
    • Remove the single silver Phillips screw from the black plastic framework directly below the Bluetooth antenna board.
    Pregunta a FixBot
    Agregar Comentario
  13. Mac mini (PowerPC) Bluetooth Antenna Replacement: paso 13, imagen 1 de 1
    • Remove the yellow tape securing the Bluetooth antenna cable to the black plastic framework.
    • Deroute the Bluetooth antenna cable.
    • Lift the silver Bluetooth antenna board out of its slot.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
8 personas más completaron esta guía.
Documentos Adjuntos
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 58
Todo El Tiempo: 13,144
