Introducción
This guide will show you the steps necessary to replace the battery in the MSI MS-1782 laptop. The battery may need to be replaced if your laptop does not retain any charge, or if it does not charge at all. Check the troubleshooting page for more information.
Qué necesitas
Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
Remove the four 5.5 mm screws holding the battery frame in place using a JIS #1 screwdriver.
Gently disconnect the cable connecting the M.2 caddy to the motherboard.
