Saltar al contenido principal
MSI GS70 Battery Replacement
Qué necesitas
  1. MSI GS70 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure that the laptop is turned off before starting.
    • Place laptop with the bottom plate facing up.
  2. MSI GS70 Battery Replacement: paso 2, imagen 1 de 1
    • Remove all screws using the JIS #1 screwdriver.
  3. MSI GS70 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the back plate.
    • Locate the battery.
  4. MSI GS70 Battery Replacement: paso 4, imagen 1 de 1
    • Locate the foil connector above the battery.
  5. MSI GS70 Battery Replacement: paso 5, imagen 1 de 1
    • Flip up both black clips with your spudger.
  6. MSI GS70 Battery Replacement: paso 6, imagen 1 de 1
    • Remove the foil connector by pulling on the blue tabs.
  7. MSI GS70 Battery Replacement: paso 7, imagen 1 de 1
    • After the foil connector is removed you will see an 8 pin connector.
    • Disconnect the 8 Pin connector.
  8. MSI GS70 Battery Replacement: paso 8, imagen 1 de 1
    • Lift the battery and remove.
Conclusión
10 personas más completaron esta guía.
3 comentarios
Anyone know what the foil connector is? Mine is broken, and needs to be replaced.
Jonathan Hawkes - Contestar
Which battery model should I buy?
slackware2007 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 19
Ultimos 30 días: 58
Todo El Tiempo: 8,936
