Saltar al contenido principal
MSI GP62MVR 6RF Leopard Pro Heatsink Replacement
Qué necesitas
  1. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Bottom Cover: paso 1, imagen 1 de 2 MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement: paso 2, imagen 1 de 2 MSI GP62MVR 6RF Leopard Pro Heatsink Replacement: paso 2, imagen 2 de 2
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement: paso 3, imagen 1 de 1
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Battery: paso 4, imagen 1 de 3 MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Battery: paso 4, imagen 2 de 3 MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Battery: paso 4, imagen 3 de 3
    • Using a Phillips #0 Screwdriver, remove the single 5.5 mm screw fastening the battery to the body of the computer.
    • Remove the battery from the device.
  5. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Speakers: paso 5, imagen 1 de 1
    • Reorient the computer, if necessary, with a 180 degree turn so that the speakers face you.
  6. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement: paso 6, imagen 1 de 1
    • On the front panel near the right speaker, there is a connection from the motherboard to the speakers.
    • Detach the white and black wiring from the clip.
  7. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement: paso 7, imagen 1 de 1
    • Peel back the electrical tape holding the speaker wire in place.
    • Remove the speakers from the front panel, pulling upward.
    • Note that the screws holding the two speakers down were already removed during the bottom cover removal.
  8. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Heatsink: paso 8, imagen 1 de 3 MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Heatsink: paso 8, imagen 2 de 3 MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Heatsink: paso 8, imagen 3 de 3
    • Using a Phillips #0 screwdriver, remove twelve 4.5 mm screws fastening the heat sink to the motherboard.
    • Unclip the red, blue, and black intertwined wire gently from the left side of the motherboard.
    • Detach the black and red wire from the right side of the motherboard, as well as peel away the black tape connecting the large black wire to the motherboard.
  9. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement: paso 9, imagen 1 de 1
    • Remove the heatsink from the device.
Conclusión
Justin Ogihara
Miembro Desde 09/18/17
29,133 Reputación
52 Guías creadas
Equipo
EDU Team Miembro de EDU Team
Staff
Miembros de 7
756 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 667
