Saltar al contenido principal
Logitech G910 Lights Replacement
Qué necesitas
  1. Logitech G910 Lights Replacement, Lights: paso 1, imagen 1 de 1
    • Unplug the keyboard from the computer.
  2. Logitech G910 Lights Replacement: paso 2, imagen 1 de 1
    • Flip the keyboard and unscrew the 15 back screws. The screws in the palm rest must be unscrewed and the palm rest removed to access the 6 screws at the bottom of the keyboard. (There are 2 lengths of screws the shorter ones are for the palm rest) There are also 2 screws under the nonslip pads of the palm rest.
  3. Logitech G910 Lights Replacement: paso 3, imagen 1 de 1
    • Release the front part using a spudger or flat screwdriver to gently pry. Lift off carefully.
  4. Logitech G910 Lights Replacement, Lift the film: paso 4, imagen 1 de 2 Logitech G910 Lights Replacement, Lift the film: paso 4, imagen 2 de 2
    • Gently lift up the plastic film in the top right corner.
Conclusión
5 personas más completaron esta guía.
3 comentarios
So what do I do after I take apart my keyboard?
CuddlyZebesian - Contestar
this guide is currently missing some steps. If you have figured it out, pls edit this guide.
tayola -
Desolder and replace LEDs the size of a grain of sand xD
This is definitely not a job I'd mark as "easy".
squallloire -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 22
Ultimos 30 días: 91
Todo El Tiempo: 6,051
