Saltar al contenido principal
Logitech G29 Driving Force Red Dial Replacement
Qué necesitas
  1. Logitech G29 Driving Force Red Dial Replacement, Red Dial: paso 1, imagen 1 de 3 Logitech G29 Driving Force Red Dial Replacement, Red Dial: paso 1, imagen 2 de 3 Logitech G29 Driving Force Red Dial Replacement, Red Dial: paso 1, imagen 3 de 3
    • Take off the 6 black hex screws holding the Playstation center cap using the H 4.0 bit. The outer diameter of these screws are 8.40mm with a length of 26mm.
    • Once the center cap is off, take the face of the wheel off the stand. Before totally taking off, disconnect the 7 pin white cable running into the base of the wheel and place base aside.
  2. Logitech G29 Driving Force Red Dial Replacement: paso 2, imagen 1 de 1
    • Remove wire connecting the PCB to the base of the wheel.
  3. Logitech G29 Driving Force Red Dial Replacement: paso 3, imagen 1 de 2 Logitech G29 Driving Force Red Dial Replacement: paso 3, imagen 2 de 2
    • Take off the 7 4.32mm diameter 8mm long silver screws holding the PCB to the black housing on the wheel using bit Ph #0.
    • Move the PCB to the side to expose the back side of the red dial. Keep the remaining white cable connected to the secondary PCB.
    • Be careful not to lose the buttons and D-pad because once the PCB was removed they can easily be lost.
  4. Logitech G29 Driving Force Red Dial Replacement: paso 4, imagen 1 de 2 Logitech G29 Driving Force Red Dial Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Press in the 3 red tabs located on the inside black housing of the dial. Using the medium sized tweezers, the black center button was pushed out to reveal 3 small black screws.
    • Using the same bit as earlier, bit Ph #00 remove the three 3.32mm diameter 5mm length screws to release the red dial.
Conclusión
Una persona más ha completado esta guía.
Ben varner
Miembro Desde 11/08/23
400 Reputación
3 Guías creadas
Equipo
IUPUI, Team 1-3, Harley Fall 2023 Miembro de IUPUI, Team 1-3, Harley Fall 2023
IUPUI-HARLEY-F23S1G3
4 Miembros
3 Guías creadas
Un comentario
Where can the part be bought?
Jesu de Gannes - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 20
Ultimos 30 días: 106
Todo El Tiempo: 1,660
