Saltar al contenido principal
Introducción
If, after reading through this guide, you are still in need of assistance, please refer back to the device page or the troubleshooting page.
Partes
No se especificaron partes.
  1. Unfold the antennas straight away from the device.
    • Unfold the antennas straight away from the device.
  2. Remove the black caps from the antennas by pulling them away from the device. Remove the black caps from the antennas by pulling them away from the device. Remove the black caps from the antennas by pulling them away from the device.
    • Remove the black caps from the antennas by pulling them away from the device.
  3. Unscrew each of the antennas from the wireless device. Unscrew each of the antennas from the wireless device. Unscrew each of the antennas from the wireless device.
    • Unscrew each of the antennas from the wireless device.
  4. Using a bit of force, remove the blue plastic case. Using a bit of force, remove the blue plastic case.
    • Using a bit of force, remove the blue plastic case.
  5. To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance. Pull the top piece upwards and away from the bottom to remove.
    • To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
    • Pull the top piece upwards and away from the bottom to remove.
  6. Locate the 2 M2.5x6mm screws that attach the motherboard to the back case. Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
    • Locate the 2 M2.5x6mm screws that attach the motherboard to the back case.
    • Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
  7. Once screws have been removed, slide the motherboard in the direction of its LED lights.
    • Once screws have been removed, slide the motherboard in the direction of its LED lights.
    • Lift motherboard up and away from the black lower casing.
Conclusión
3 personas más completaron esta guía.
Aaron Brown
Miembro Desde 11/10/11
163 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 17-7, Regan Fall 2011 Miembro de Cal Poly, Team 17-7, Regan Fall 2011
CPSU-REGAN-F11S17G7
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 3,158
