Saltar al contenido principal
Linksys WRT54G Motherboard Component Replacement
Qué necesitas
  1. Linksys WRT54G Motherboard Component Replacement, Antennas: paso 1, imagen 1 de 1
    • Unfold the antennas straight away from the device.
  2. Linksys WRT54G Motherboard Component Replacement: paso 2, imagen 1 de 3 Linksys WRT54G Motherboard Component Replacement: paso 2, imagen 2 de 3 Linksys WRT54G Motherboard Component Replacement: paso 2, imagen 3 de 3
    • Remove the black caps from the antennas by pulling them away from the device.
  3. Linksys WRT54G Motherboard Component Replacement: paso 3, imagen 1 de 3 Linksys WRT54G Motherboard Component Replacement: paso 3, imagen 2 de 3 Linksys WRT54G Motherboard Component Replacement: paso 3, imagen 3 de 3
    • Unscrew each of the antennas from the wireless device.
  4. Linksys WRT54G Motherboard Component Replacement, Casing: paso 4, imagen 1 de 2 Linksys WRT54G Motherboard Component Replacement, Casing: paso 4, imagen 2 de 2
    • Using a bit of force, remove the blue plastic case.
  5. Linksys WRT54G Motherboard Component Replacement, Motherboard: paso 5, imagen 1 de 2 Linksys WRT54G Motherboard Component Replacement, Motherboard: paso 5, imagen 2 de 2
    • To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
    • Pull the top piece upwards and away from the bottom to remove.
  6. Linksys WRT54G Motherboard Component Replacement: paso 6, imagen 1 de 2 Linksys WRT54G Motherboard Component Replacement: paso 6, imagen 2 de 2
    • Locate the 2 M2.5x6mm screws that attach the motherboard to the back case.
    • Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
  7. Linksys WRT54G Motherboard Component Replacement: paso 7, imagen 1 de 1
    • Once screws have been removed, slide the motherboard in the direction of its LED lights.
    • Lift motherboard up and away from the black lower casing.
  8. Linksys WRT54G Motherboard Component Replacement, Motherboard Component: paso 8, imagen 1 de 1
    • Obtain a desoldering wick (Desoldering Braid). Plug in soldering iron and allow to heat. For soldering information, refer to the iFixit soldering guide (Cómo soldar y desoldar conexiones).
    • Make sure that the soldering iron is not resting on top of anything that would be damaged by the heat.
  9. Linksys WRT54G Motherboard Component Replacement: paso 9, imagen 1 de 2 Linksys WRT54G Motherboard Component Replacement: paso 9, imagen 2 de 2
    • Identify the functional component which will be removed.
    • Turn the board over so that the pins holding the component in are exposed.
  10. Linksys WRT54G Motherboard Component Replacement: paso 10, imagen 1 de 1
Conclusión
Una persona más ha completado esta guía.
Nicole C
Miembro Desde 10/12/11
102 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 17-7, Regan Fall 2011 Miembro de Cal Poly, Team 17-7, Regan Fall 2011
CPSU-REGAN-F11S17G7
Miembros de 4
4 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 3,926
