Saltar al contenido principal
Linksys WRT54G Antennas Replacement
Qué necesitas
  1. Linksys WRT54G Antennas Replacement, Antennas: paso 1, imagen 1 de 1
    • Unfold the antennas straight away from the device.
  2. Linksys WRT54G Antennas Replacement: paso 2, imagen 1 de 3 Linksys WRT54G Antennas Replacement: paso 2, imagen 2 de 3 Linksys WRT54G Antennas Replacement: paso 2, imagen 3 de 3
    • Remove the black caps from the antennas by pulling them away from the device.
  3. Linksys WRT54G Antennas Replacement: paso 3, imagen 1 de 3 Linksys WRT54G Antennas Replacement: paso 3, imagen 2 de 3 Linksys WRT54G Antennas Replacement: paso 3, imagen 3 de 3
    • Unscrew each of the antennas from the wireless device.
  4. Linksys WRT54G Antennas Replacement, Antennas: paso 4, imagen 1 de 2 Linksys WRT54G Antennas Replacement, Antennas: paso 4, imagen 2 de 2
    • Once the old antennas are removed, replace them with them with the new ones by screwing them on the device.
Conclusión
Aaron Brown
Miembro Desde 10/11/11
163 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 17-7, Regan Fall 2011 Miembro de Cal Poly, Team 17-7, Regan Fall 2011
CPSU-REGAN-F11S17G7
4 Miembros
4 Guías creadas
2 comentarios
I have a wrt54gs and the antennas are plastic crap with no cuff to unscrew. They are fastened in by "body snaps" like most of the cheap crap that's made in china. Off to find instructions for router disassembly. Just thought you should know this won't necessarily work for the models listed.
Ed Rutmayer - Contestar
Most do not have removeable antennaes
tom - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 5,762
