Introducción
The Levoit Core 300-RAC receives electricity from a power cord, providing the energy needed to power on the device. If the power cord is severed, frayed, or damaged in any way, it could be dangerous or even impossible to operate your air purifier. The factory cord is 1.8 meters (about 6 feet) long and uses a Type A American plug. When looking for a replacement, ensure it's rated for 100-240V and 50/60Hz. Follow this guide to learn how to replace your existing power cord.
Before you begin, turn off your device and unplug it from the outlet.
Qué necesitas
Use a Phillips #2 screwdriver to remove the four screws that go through the four white tabs inside the device
