Saltar al contenido principal
Lenovo Yoga 720-15IKB Bottom Cover Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Lenovo Yoga 720-15IKB Bottom Cover Replacement, Bottom Cover: paso 1, imagen 1 de 2 Lenovo Yoga 720-15IKB Bottom Cover Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Start by flipping the device over so that you see the screws.
    • Remove the 7 T5 short screws.
    • Remove the 3 long T5 screws.
  2. Lenovo Yoga 720-15IKB Bottom Cover Replacement: paso 2, imagen 1 de 2 Lenovo Yoga 720-15IKB Bottom Cover Replacement: paso 2, imagen 2 de 2
    • Starting at the left USB port use you opening tool to gently pry up the bottom case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop's edge as shown by the arrows.
    • Do NOT pry along the top side, or you will damage the casing. Stay with the arrows.
  3. Lenovo Yoga 720-15IKB Bottom Cover Replacement: paso 3, imagen 1 de 1
    • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the bottom case.
Conclusión
dkay
Miembro Desde 01/05/20
226 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 103
