Saltar al contenido principal
Lenovo YOGA 730-15IWL Battery Replacement
Qué necesitas
  1. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover screws: paso 1, imagen 1 de 1
    • Remove the screws (M2.0 x 7.0 mm, Torx).
  2. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover: paso 2, imagen 1 de 1
    • Remove the base cover. Consider using a spudger.
  3. Lenovo YOGA 730-15IWL Battery Replacement, Remove the battery: paso 3, imagen 1 de 1
    • Unplug the battery connector in the direction shown by arrow
    • Remove the screws (M2.0 x 4.5 mm).
    • Remove the battery pack.
Conclusión
To replace the battery & reassemble your device, follow these instructions in reverse order.
2 personas más completaron esta guía.
Max Kletskov
Miembro Desde 04/22/20
40,307 Reputación
16 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
17,277 Guías creadas
2 comentarios
My issue with my Lenovo Yoga 730-15 laptop was not the battery I just successfully replaced. It still does not turn on. The Power button light up for a short time when pressed to power up the laptop. However, it then goes out and the laptop does not startup. Any Ideas?? Thanks
Al Cross - Contestar
Check thermal paste. May be getting hot and shutting back off.
William Mobley - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 15
Ultimos 30 días: 50
Todo El Tiempo: 1,372
