Saltar al contenido principal
Lenovo ThinkPad X280 Speaker Replacement
Qué necesitas
  1. Lenovo ThinkPad X280 Speaker Replacement, Back Panel: paso 1, imagen 1 de 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Speaker Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad X280 Speaker Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Speaker Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad X280 Speaker Replacement: paso 3, imagen 2 de 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Speaker Replacement, Battery: paso 4, imagen 1 de 3 Lenovo ThinkPad X280 Speaker Replacement, Battery: paso 4, imagen 2 de 3 Lenovo ThinkPad X280 Speaker Replacement, Battery: paso 4, imagen 3 de 3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280 Speaker Replacement, Speakers: paso 5, imagen 1 de 3 Lenovo ThinkPad X280 Speaker Replacement, Speakers: paso 5, imagen 2 de 3 Lenovo ThinkPad X280 Speaker Replacement, Speakers: paso 5, imagen 3 de 3
    • Using a Phillips #1 screwdriver, remove two 5 mm screws from each speaker.
    • Once done, the speakers should still be attached with a red wire connecting to each other.
  6. Lenovo ThinkPad X280 Speaker Replacement: paso 6, imagen 1 de 2 Lenovo ThinkPad X280 Speaker Replacement: paso 6, imagen 2 de 2
    • Using the black spudger, push the white plastic connector out of the the tan plug.
  7. Lenovo ThinkPad X280 Speaker Replacement: paso 7, imagen 1 de 1
    • Remove speakers and wiring from device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 34
Todo El Tiempo: 1,396
