Saltar al contenido principal
Lenovo ThinkPad X1 Yoga (6th Gen) Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Yoga (6th Gen) Battery Replacement, Base Panel: paso 1, imagen 1 de 3 Lenovo ThinkPad X1 Yoga (6th Gen) Battery Replacement, Base Panel: paso 1, imagen 2 de 3 Lenovo ThinkPad X1 Yoga (6th Gen) Battery Replacement, Base Panel: paso 1, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove the five 5.0 mm screws from the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) Battery Replacement, Battery: paso 2, imagen 1 de 3 Lenovo ThinkPad X1 Yoga (6th Gen) Battery Replacement, Battery: paso 2, imagen 2 de 3 Lenovo ThinkPad X1 Yoga (6th Gen) Battery Replacement, Battery: paso 2, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove the five 4.5 mm screws securing the battery.
    • Lift the battery up and out.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 22
Ultimos 30 días: 115
Todo El Tiempo: 1,871
