Saltar al contenido principal
Lenovo ThinkPad X1 Extreme Speakers Replacement
Qué necesitas
  1. Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: paso 1, imagen 1 de 3 Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: paso 1, imagen 2 de 3 Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: paso 1, imagen 3 de 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Speakers Replacement, Speakers: paso 2, imagen 1 de 1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Speakers Replacement: paso 3, imagen 1 de 1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
Conclusión
Kristen Gismondi
Miembro Desde 11/12/14
92,233 Reputación
241 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 119
19,522 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 16
Ultimos 30 días: 28
Todo El Tiempo: 474
