Introducción
Welcome to the trackpad replacement guide for the Lenovo Thinkpad T580.
This guide will detail the steps necessary to replace the trackpad.
The most common reasons why this component would need to be replaced is because:
- The mouse skips around often
- The trackpad does not function
- The trackpad is visibly damaged
If you are not experiencing these problems with this component consider examining the troubleshooting page for this device.
There are no specialized skills required for replacing the trackpad.
Qué necesitas
Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
