Saltar al contenido principal
Lenovo ThinkPad T560 Keyboard Replacement
Qué necesitas
  1. Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 Lenovo ThinkPad T560 Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • Using the spudger, slide the keyboard up towards the display at the notches created for this purpose.
  2. Lenovo ThinkPad T560 Keyboard Replacement: paso 2, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove the six 3.5 mm screws that secure the keyboard to the laptop.
  3. Lenovo ThinkPad T560 Keyboard Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad T560 Keyboard Replacement: paso 3, imagen 2 de 2
    • Using the spudger, push the keyboard toward the display and then slide it back out of the connector at top of the keyboard to remove.
    • Don't pull on the keyboard as it is attached by two ZIF connectors underneath.
    • Flip the keyboard over to expose the keyboard's connections to the motherboard and touchpad.
  4. Lenovo ThinkPad T560 Keyboard Replacement: paso 4, imagen 1 de 2 Lenovo ThinkPad T560 Keyboard Replacement: paso 4, imagen 2 de 2
    • Using the spudger, open the latches securing the keyboard's connections to the motherboard and touchpad.
    • Remove the keyboard.
Conclusión
Equipo
Clemson, Team 1-3, Hunter Spring 2022 Miembro de Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 23
Ultimos 30 días: 56
Todo El Tiempo: 1,658
