Saltar al contenido principal
Lenovo ThinkPad T500 Speaker Replacement
Qué necesitas
  1. Lenovo ThinkPad T500 Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Remove the eight 14mm screws using the Phillips #0 Screwdriver.
  2. Lenovo ThinkPad T500 Speaker Replacement: paso 2, imagen 1 de 1
    • Lift the palm rest panel up.
    • Be sure to lift the panel slowly; there is a ribbon cable attached to the bottom.
  3. Lenovo ThinkPad T500 Speaker Replacement: paso 3, imagen 1 de 1
    • Use the spudger to disconnect the ribbon cable.
  4. Lenovo ThinkPad T500 Speaker Replacement: paso 4, imagen 1 de 1
    • With the panel disconnected, lift the keyboard.
    • As with the panel, lift the keyboard slowly; there is a ribbon cable attached to the bottom.
  5. Lenovo ThinkPad T500 Speaker Replacement: paso 5, imagen 1 de 1
    • Disconnect the ribbon cable with the spudger.
  6. Lenovo ThinkPad T500 Speaker Replacement: paso 6, imagen 1 de 2 Lenovo ThinkPad T500 Speaker Replacement: paso 6, imagen 2 de 2
    • Remove the keyboard and the panel.
    • Using the Phillips #0 Screwdriver, remove the three 3 mm screws that are at the bottom sides and near the top-left of the speaker cover.
    • Disconnect the orange and blue cables next to the left side of the speaker cover.
  7. Lenovo ThinkPad T500 Speaker Replacement: paso 7, imagen 1 de 1
    • Remove the speaker cover by carefully pulling up and towards you.
  8. Lenovo ThinkPad T500 Speaker Replacement: paso 8, imagen 1 de 1
    • Remove the four 3mm screws on the speakers with the Phillips #0 Screwdriver.
  9. Lenovo ThinkPad T500 Speaker Replacement: paso 9, imagen 1 de 2 Lenovo ThinkPad T500 Speaker Replacement: paso 9, imagen 2 de 2
    • Using the spudger, lift the tape over the right speaker's wires.
    • Although the right speaker is unscrewed, it can't be removed from the laptop yet!
  10. Lenovo ThinkPad T500 Speaker Replacement: paso 10, imagen 1 de 2 Lenovo ThinkPad T500 Speaker Replacement: paso 10, imagen 2 de 2
    • Detach the blue and orange cables from the left speaker's clamps.
  11. Lenovo ThinkPad T500 Speaker Replacement: paso 11, imagen 1 de 3 Lenovo ThinkPad T500 Speaker Replacement: paso 11, imagen 2 de 3 Lenovo ThinkPad T500 Speaker Replacement: paso 11, imagen 3 de 3
    • Locate the plug in the middle of the laptop that connects both the left and right speakers.
    • Use the spudger to unplug the speaker wires.
  12. Lenovo ThinkPad T500 Speaker Replacement: paso 12, imagen 1 de 1
    • Remove the speakers.
Conclusión
nicO
Miembro Desde 04/14/15
15,927 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
34 Miembros
597 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 1,228
