Saltar al contenido principal
Lenovo ThinkPad T490 SSD Replacement
Qué necesitas
  1. Lenovo ThinkPad T490 SSD Replacement, Base Plate: paso 1, imagen 1 de 1
    • Loosen the screws from the base plate.
    • Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
    • These screws are captive - they will not fully come out after being unscrewed.
  2. Lenovo ThinkPad T490 SSD Replacement: paso 2, imagen 1 de 1
    • Once the screws have been loosened, start to remove the base plate.
    • Insert the iFixit opening tool into the space between the base plate and the chassis.
    • Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
  3. Lenovo ThinkPad T490 SSD Replacement: paso 3, imagen 1 de 1
    • Fully remove the base .
    • Grab the edge of the cover and lift the cover away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  4. Lenovo ThinkPad T490 SSD Replacement, SSD: paso 4, imagen 1 de 2 Lenovo ThinkPad T490 SSD Replacement, SSD: paso 4, imagen 2 de 2
    • Grab the battery pull-tab at the top of the connector plugin.
    • Pull the connector straight out in the direction toward the cable.
  5. Lenovo ThinkPad T490 SSD Replacement: paso 5, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the 3.7 mm Phillips screw securing the SSD.
  6. Lenovo ThinkPad T490 SSD Replacement: paso 6, imagen 1 de 1
    • Disconnect the SSD from its socket.
    • If it requires excess force to remove, wiggle side to side while pulling.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Brenden.Welling
Miembro Desde 09/23/24
97 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 29
Ultimos 30 días: 127
Todo El Tiempo: 327
