Saltar al contenido principal
Lenovo ThinkPad T490 RAM Replacement
Qué necesitas
  1. Lenovo ThinkPad T490 RAM Replacement, Unscrew the base plate: paso 1, imagen 1 de 1
    • Remove the screws from the base plate for access to the motherboard using a Philips #00 screwdriver.
  2. Lenovo ThinkPad T490 RAM Replacement, Pry the base plate off: paso 2, imagen 1 de 2 Lenovo ThinkPad T490 RAM Replacement, Pry the base plate off: paso 2, imagen 2 de 2
    • Once the screws are off, start to pry the base plate off.
    • Fully remove the base plate so you can access the RAM.
  3. Lenovo ThinkPad T490 RAM Replacement, Locate components: paso 3, imagen 1 de 1
    • Locate the RAM module (blue box on the left)…
    • …and the laptop's battery (pink box on the right).
  4. Lenovo ThinkPad T490 RAM Replacement, Disconnect the battery: paso 4, imagen 1 de 2 Lenovo ThinkPad T490 RAM Replacement, Disconnect the battery: paso 4, imagen 2 de 2
    • First, for the reinstallation process, disconnect and remove the battery.
    • Be cautious when handling any batteries. A punctured or damaged battery is a fire risk and should be disposed of immediately.
    • To remove the RAM battery, tug the black cables and disconnect the metal head from the socket.
  5. Lenovo ThinkPad T490 RAM Replacement, Remove the RAM stick: paso 5, imagen 1 de 2 Lenovo ThinkPad T490 RAM Replacement, Remove the RAM stick: paso 5, imagen 2 de 2
    • For the RAM stick, first remove the black flap that is covering it.
    • Once the black flap is removed, slide the RAM stick out for further inspection. Slide it back in and place the black flap over it to restart the process.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 38
Ultimos 30 días: 169
Todo El Tiempo: 1,274
