Saltar al contenido principal
Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement
Qué necesitas
  1. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement, Base Plate: paso 1, imagen 1 de 1
    • Loosen the screws from the base plate.
    • Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
    • These screws are captive - they will not fully come out after being unscrewed.
  2. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement: paso 2, imagen 1 de 1
    • Once the screws have been loosened, start to remove the base plate.
    • Insert the iFixit opening tool into the space between the base plate and the chassis.
    • Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
  3. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement: paso 3, imagen 1 de 1
    • Fully remove the base .
    • Grab the edge of the cover and lift the cover away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  4. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement, Fan and Heat Sink Assembly: paso 4, imagen 1 de 1
    • Use a Philips #1 screwdriver to loosen the five captive screws that secure the heat sink.
  5. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement: paso 5, imagen 1 de 1
    • Disconnect the fan connector from its motherboard socket.
  6. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement: paso 6, imagen 1 de 1
    • Gently lift the fan and heat sink assembly up and out of the chassis.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Reiona Silas
Miembro Desde 09/23/24
97 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 61
Todo El Tiempo: 179
