Saltar al contenido principal
Lenovo ThinkPad T490 Battery Replacement
Qué necesitas
  1. Lenovo ThinkPad T490 Battery Replacement, Base Plate: paso 1, imagen 1 de 1
    • Loosen the screws from the base plate.
    • Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
    • These screws are captive - they will not fully come out after being unscrewed.
  2. Lenovo ThinkPad T490 Battery Replacement: paso 2, imagen 1 de 1
    • Once the screws have been loosened, start to remove the base plate.
    • Insert the iFixit opening tool into the space between the base plate and the chassis.
    • Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
  3. Lenovo ThinkPad T490 Battery Replacement: paso 3, imagen 1 de 1
    • Fully remove the base .
    • Grab the edge of the cover and lift the cover away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  4. Lenovo ThinkPad T490 Battery Replacement, Battery: paso 4, imagen 1 de 3 Lenovo ThinkPad T490 Battery Replacement, Battery: paso 4, imagen 2 de 3 Lenovo ThinkPad T490 Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Remove the four 3 mm screws securing the battery with a Phillips #000 screwdriver.
  5. Lenovo ThinkPad T490 Battery Replacement: paso 5, imagen 1 de 1
    • Use tweezers or your fingernails to disconnect the battery from its motherboard socket.
  6. Lenovo ThinkPad T490 Battery Replacement: paso 6, imagen 1 de 1
    • Lift up and remove the battery from the device.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Joshua
Miembro Desde 09/23/24
97 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 42
Ultimos 30 días: 170
Todo El Tiempo: 450
