Introducción
If your Lenovo ThinkPad T460s has a depleting battery life (1-2 hours without charging), use this guide to replace the battery module.
This guide will guide you through how to replace both batteries in the Lenovo ThinkPad T460s (yes, there are two!). Before using this guide, make sure you have two new batteries to be replaced and the tools we list.
Before beginning, make sure to power off your laptop completely and disconnect from any external power source.
If your battery is swollen, you may refer to this link.
Qué necesitas
Remove the five 5.5mm Phillips #1 screws securing the back cover.
Lift and remove the back cover.
For optimal performance, after completing this guide, calibrate your newly installed battery.
13 personas más completaron esta guía.
12 comentarios
I have a question, please. Are the two batteries identical?
No, the batteries are different.
Battery 1 Part Number: 00HW022. (23.510 mWh)
Battery 2 Part Number: 01AV405. (26.330 mWh)
Best regards!
Rafael -
Hi there, anyone know which battery is number 1? - only battery 1 is broken in my laptop, 2 still works.
Hello!!?? Any in iFixit knows the answer to Jonas’ question???
Ruben -
Battery 1 is 00HW022. (23.510 mWh)
Battery 2 is 01AV405. (26.330 mWh)
You can confirm it by yourself running powercfg /batteryreport on cmd
Hope it helps!
Rafael -
