Saltar al contenido principal
Lenovo ThinkPad T430s Hard Drive Replacement
Qué necesitas
  1. Lenovo ThinkPad T430s Hard Drive Replacement, Battery: paso 1, imagen 1 de 3 Lenovo ThinkPad T430s Hard Drive Replacement, Battery: paso 1, imagen 2 de 3 Lenovo ThinkPad T430s Hard Drive Replacement, Battery: paso 1, imagen 3 de 3
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s Hard Drive Replacement, Hard Drive: paso 2, imagen 1 de 1
    • Unscrew the 40 mm screw with the Phillips head #1 screwdriver.
  3. Lenovo ThinkPad T430s Hard Drive Replacement: paso 3, imagen 1 de 1
    • Pull the hard drive out with the black ribbon attached to it.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 54
Ultimos 30 días: 107
Todo El Tiempo: 2,208
