Saltar al contenido principal
Lenovo ThinkPad L490 Lower Case Replacement
Qué necesitas
  1. Lenovo ThinkPad L490 Lower Case Replacement, Lower Case: paso 1, imagen 1 de 2 Lenovo ThinkPad L490 Lower Case Replacement, Lower Case: paso 1, imagen 2 de 2
    • Completely shut down your device and disconnect any peripheries before beginning.
    • Lay the laptop down with the lower case facing up.
    • Use a Phillips #00 screwdriver to remove eight 3 mm screws that secure the lower case.
  2. Lenovo ThinkPad L490 Lower Case Replacement: paso 2, imagen 1 de 2 Lenovo ThinkPad L490 Lower Case Replacement: paso 2, imagen 2 de 2
    • Lift the lower case up and off of the chassis.
    • If necessary, insert an opening pick into the gap between the lower case and chassis and pry around the entire perimeter until the lower case fully releases.
Conclusión
Connor
Miembro Desde 03/29/22
12,298 Reputación
64 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 118
19,526 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 46
