Saltar al contenido principal
Lenovo ThinkPad L440 Hard Drive Replacement
Qué necesitas
  1. Lenovo ThinkPad L440 Hard Drive Replacement, Battery: paso 1, imagen 1 de 3 Lenovo ThinkPad L440 Hard Drive Replacement, Battery: paso 1, imagen 2 de 3 Lenovo ThinkPad L440 Hard Drive Replacement, Battery: paso 1, imagen 3 de 3
    • Open the laptop to access the power button.
    • Hold the power button in the top right until the computer powers off.
    • Turn the computer over so that the bottom of the computer is facing up
  2. Lenovo ThinkPad L440 Hard Drive Replacement: paso 2, imagen 1 de 1
    • On the left side under the raised surface, move the tab to the left towards the unlocked symbol. Repeat this on the right side and move the tab to the right towards the unlocked symbol.
  3. Lenovo ThinkPad L440 Hard Drive Replacement: paso 3, imagen 1 de 2 Lenovo ThinkPad L440 Hard Drive Replacement: paso 3, imagen 2 de 2
    • From the top of the laptop, slide the raised surface away from the rest of the laptop and out of its slot to remove the battery from the computer.
  4. Lenovo ThinkPad L440 Hard Drive Replacement, Back Panel: paso 4, imagen 1 de 2 Lenovo ThinkPad L440 Hard Drive Replacement, Back Panel: paso 4, imagen 2 de 2
    • Loosen the four retainer screws on the bottom of the laptop using a Phillips #0 screwdriver.
    • These four screws are attached to the panel with washers, so they will spin freely when they are loose and will come off with the panel.
  5. Lenovo ThinkPad L440 Hard Drive Replacement: paso 5, imagen 1 de 2 Lenovo ThinkPad L440 Hard Drive Replacement: paso 5, imagen 2 de 2
    • With your fingers, lift up the back panel from the left side.
  6. Lenovo ThinkPad L440 Hard Drive Replacement, Hard Drive: paso 6, imagen 1 de 2 Lenovo ThinkPad L440 Hard Drive Replacement, Hard Drive: paso 6, imagen 2 de 2
    • Remove the single 3.5 mm screw next to the hard drive using a Phillips #00 screwdriver.
    • Remove the hard drive from the laptop.
Conclusión
Kristen Gismondi
Miembro Desde 11/12/14
92,209 Reputación
241 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
119 Miembros
19,481 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 35
Todo El Tiempo: 62
