Saltar al contenido principal
Lenovo ThinkPad Edge E420s Hard Drive Replacement
Qué necesitas
  1. Lenovo ThinkPad Edge E420s Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Lenovo ThinkPad Edge E420s Hard Drive Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove one M2 x 3mm screw from the side of the device.
  3. Lenovo ThinkPad Edge E420s Hard Drive Replacement: paso 3, imagen 1 de 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: paso 3, imagen 2 de 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: paso 3, imagen 3 de 3
    • Swing the cover out slightly like a hinge.
    • Pull the cover directly away from the case towards the base of the laptop.
    • Lift the cover up and away from the device to remove it.
    • You may hear a slight pop when you pull the cover off.
  4. Lenovo ThinkPad Edge E420s Hard Drive Replacement: paso 4, imagen 1 de 1
    • Use the clear tab to slide the hard drive out of the device.
  5. Lenovo ThinkPad Edge E420s Hard Drive Replacement: paso 5, imagen 1 de 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: paso 5, imagen 2 de 3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: paso 5, imagen 3 de 3
    • To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
    • Slide the old hard drive directly out.
    • When reassembling, make sure the hard drive is securely in the case before beginning.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 35
Todo El Tiempo: 2,837
