Saltar al contenido principal
Lenovo ThinkCentre A70z Backlight Cable Replacement
Qué necesitas
  1. Lenovo ThinkCentre A70z  Backlight Cable Replacement, Remove Conductive Tape from Backlight Cable: paso 1, imagen 1 de 1
    • Remove conductive tape wrapped around the backlight cable as below seen below.
    • The issue has a low failure rate with the woven type of conductive tape. However, has a high failure rate with an aluminum foil type of conductive tape.
  2. Lenovo ThinkCentre A70z  Backlight Cable Replacement: paso 2, imagen 1 de 3 Lenovo ThinkCentre A70z  Backlight Cable Replacement: paso 2, imagen 2 de 3 Lenovo ThinkCentre A70z  Backlight Cable Replacement: paso 2, imagen 3 de 3
    • Order special tape that has sponge as noted: 03T9708 34.3BE7.001 FRU_EMI_GASKET_MB_SHEILDING_TOYAMA
    • Replace previous conductive tape with new tape 03T9708 after Removing original tapes.
Conclusión
2 personas más completaron esta guía.
James Finch
Miembro Desde 10/14/17
2,298 Reputación
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 29
Todo El Tiempo: 678
