Saltar al contenido principal
Lenovo Miix 2 Speakers Replacement
Qué necesitas
  1. Lenovo Miix 2 Speakers Replacement, Battery: paso 1, imagen 1 de 2 Lenovo Miix 2 Speakers Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Lenovo Miix 2 Speakers Replacement: paso 2, imagen 1 de 2 Lenovo Miix 2 Speakers Replacement: paso 2, imagen 2 de 2
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Lenovo Miix 2 Speakers Replacement: paso 3, imagen 1 de 2 Lenovo Miix 2 Speakers Replacement: paso 3, imagen 2 de 2
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Lenovo Miix 2 Speakers Replacement: paso 4, imagen 1 de 2 Lenovo Miix 2 Speakers Replacement: paso 4, imagen 2 de 2
    • Remove the battery by prying up with your fingers or a plastic opening tool.
  5. Lenovo Miix 2 Speakers Replacement, Speakers: paso 5, imagen 1 de 2 Lenovo Miix 2 Speakers Replacement, Speakers: paso 5, imagen 2 de 2
    • Remove the red and black connector cable linking the speakers to the motherboard with tweezers by pulling the connector to the left with a light degree of force.
    • To properly remove the speakers from the casing, push gently left until it shifts, then pull directly up.
Conclusión
Diana Chiu
Miembro Desde 07/14/14
654 Reputación
4 Guías creadas
Equipo
Kid fixers Miembro de Kid fixers
Community
158 Miembros
296 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 9
Todo El Tiempo: 953
